Image #1
Add Note Edit Step 9 — Motherboard  ¶
  • Use the tip of a spudger to pry the power board connector out of its socket on the motherboard.
Image #1 Image #2
Add Note Edit Step 10  ¶
  • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following three ZIF sockets:
    • Lower touchscreen cable
    • Lower LCD cable
    • Power board cable
  • Be sure you are prying up on the hinged retaining flaps, not the sockets themselves.
  • After flipping up the locking tabs on all three sockets, use your fingers or a pair of tweezers to gently pull the cables straight out of their sockets.
Image #1 Image #2
Add Note Edit Step 11  ¶
  • Use your fingernail or the edge of a plastic opening tool to carefully flip up the touchscreen ribbon cable retaining flap.
  • Make sure you are flipping up the retaining flap, not the socket itself.
  • Use the tip of a spudger to pull the touchscreen ribbon cable straight out of its socket.
Image #1 Image #2
Add Note Edit Step 12  ¶
  • Use your fingernail or the edge of a plastic opening tool to carefully flip up the dual camera ribbon cable retaining flap.
  • Use the tip of a spudger to pull the dual camera ribbon cable straight out of its socket.
Image #1
Add Note Edit Step 13  ¶
  • With the tip of a spudger, Pry the microphone antenna up off its socket on the motherboard.
Image #1
Add Note Edit Step 14  ¶
  • Remove the following four Phillips screws securing the motherboard to the DSi framework.
    • Three longer screws.
    • One short screw.
  • Pull the microphone and Wi-Fi antenna cables out of the notch cut into the motherboard near the headphone jack.
Image #1 Image #2 Image #3
Add Note Edit Step 15  ¶
  • Slightly lift the motherboard upwards to reveal the upper LCD ribbon cable above the ABXY buttons .
  • Use your fingernail or the edge of a plastic opening tool to carefully flip up the upper LCD ribbon cable retaining flap.
  • Remove the motherboard from the DSi.
Image #1 Image #2
Add Note Edit Step 16 — Lower LCD Assembly  ¶
  • Use the tip of a spudger to pry the metal backing of the lower LCD up from the DSi's framework.
  • Lift the lower LCD assembly out of the DSi.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Soldering Station
$24.95 · 13 In stock
Plastic Opening Tools
Related Products
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 31 In stock
Inspection Scope
$39.95 · 40 In stock
Frictionless Ratchet
$24.95 · 49 In stock
Portable Anti-Static Mat
$24.95 · 19 In stock
