Installing Nintendo DSi Stylus Housing
Replace the plastic stylus housing on your Nintendo DSi.
  • Add Note x
Use this guide to remove the plastic stylus housing from your DSi.
Sections
first image
thumb image 1
thumb image 2
  • Unscrew the two Phillips screws securing the battery cover to the lower case.
  • The screws remain captive to the battery cover.
  • Grasp the battery cover and lift out of the lower case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Wedge the edge of an opening tool in between the top of the battery and its lower case housing and pry upwards to dislodge the battery.
  • Grasp the battery and remove it from the DSi.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3 — Lower Case Assembly  ¶
  • Two screws are hidden underneath two rubber feet highlighted in red.
  • Use the tip of a spudger to pry the rubber foot out of the lower case.
  • In the same manner, remove the remaining foot off the lower case.
Next » « Previous
