Installing Nintendo DS Lite Touchscreen
Replacement of Nintendo DS Lite touchscreen.
  • Add Note x
  • x 7
After many hours of stylus use, your Nintendo DS Lite's touchscreen has finally died. We've got you covered with this touchscreen replacement guide!
Sections
first image
thumb image 1
thumb image 2
  • Unscrew the Phillips screw securing the battery cover to the lower case.
  • The screw remains captive to the battery cover.
  • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
first image
Add Note Edit Step 2  ¶
  • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
  • Remove the battery from the DS Lite.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3 — Lower Case  ¶
  • Use the tip of a spudger to pry both rubber feet off the DS Lite.
Next » « Previous
