Installing Nintendo DS Lite Rear Display Bezel
Replacement of the Nintendo DS Lite rear display bezel.
  • Add Note x
  • x 4
Replace the rear display bezel to give you DS Lite a face lift!
Image #1 Image #2
  • Unscrew the Phillips screw securing the battery cover to the lower case.
  • The screw remains captive to the battery cover.
  • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
Image #1
Add Note Edit Step 2  ¶
  • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
  • Remove the battery from the DS Lite.
Image #1 Image #2
Add Note Edit Step 3 — Lower Case  ¶
  • Use the tip of a spudger to pry both rubber feet off the DS Lite.
Image #1
Add Note Edit Step 4  ¶
  • Remove the following screws securing the lower case to the body of the DS Lite:
    • Two 4.3 mm gold Phillips screws
    • One 3.9 mm black Tri-Wing screw
    • One 3.3 mm silver Phillips screw
    • Three 5.5 mm silver Tri-Wing screws
Image #1 Image #2 Image #3
Add Note Edit Step 5  ¶
  • Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite.
  • Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
  • Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
Image #1
Add Note Edit Step 6  ¶
  • Lift the lower case away from the rest of the DS Lite.
Image #1 Image #2
Add Note Edit Step 7 — Trigger Buttons  ¶
  • Lift both trigger buttons out of the DS Lite.
  • The trigger buttons are held in very loosely by small metal pegs and springs. Don't lose track of these pieces.
  • The second picture shows the correct configuration of the trigger assembly for reassembly purposes.
Image #1
Add Note Edit Step 8 — Wi-Fi Board  ¶
  • Use the flat edge of a spudger to pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Tri-wing Y1 Screwdriver
$9.95 · 50+ In stock
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 10 In stock
Popular Products
iPad 2 Front Panel
$94.95 · 2 In stock
iPhone 3G Replacement Battery
$14.95 · 50+ In stock
T8 Torx Security Bit Screwdriver
$6.95 · 42 In stock
T5 Torx Screwdriver
$6.95 · 26 In stock
