Image #1 Image #2
Add Note Edit Step 25  ¶
  • With all of the sides free, lift the upper display front panel off the display bezel.
Image #1
Add Note Edit Step 26 — Rear Display Bezel  ¶
  • Remove the six 3.6 mm Phillips screws securing the rear display bezel to the front display bezel.
Image #1 Image #2
Add Note Edit Step 27  ¶
  • Flip the device over so that the rear display bezel is on top and the hinge is on the side opposite from you.
  • Lift the edge of the rear display bezel closest to you and rotate it towards the hinge.
  • Continue to lift the rear display bezel off the rest of the device until it is free.
  • There are clips toward the bottom of the rear display bezel holding it in place. Use enough force to disengage the clips, but be careful not to break them.
Image #1
Add Note Edit Step 28 — Upper Display Assembly  ¶
  • Remove the 3D adjustment switch from the front display bezel.
  • This step is not necessary for disassembly, but the switch is likely to fall out on its own. By removing it yourself, you reduce the chance of losing it.
Image #1 Image #2 Image #3
Add Note Edit Step 29  ¶
  • Insert a metal probe into the space above the ABXY buttons with the point touching the metal hinge.
  • Push the hinge towards the center of the upper case. This will require a fair amount of force.
  • Before and after images of the hinge location when looking at the back of the upper display are shown.
Add Note Edit Step 30  ¶
  • Slowly pull the upper display assembly away from the upper case.
  • Make sure that the various ribbon cables are being fed through the slit in the upper case.
  • Separate the upper display assembly from the upper case.
Image #1 Image #2
Add Note Edit Step 31 — Speaker Assembly  ¶
  • Carefully feed the speaker assembly ribbon cable through the hole in the upper display bezel.
  • You may have to gently fold the edges of the connector end of the ribbon cable to allow it to fit.
Image #1
Add Note Edit Step 32  ¶
  • Remove the 2.5 mm Phillips screw securing the right speaker board to the upper display bezel.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Heat Gun
$24.95
Plastic Opening Tools
$6.95 · 15 In stock
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 11 In stock
Popular Products
iPad 2 Volume and Power Button Cable
$24.95 · 31 In stock
iPhone 5 Liberation Kit
$9.95 · 23 In stock
Small Suction Cup
Detailing Brush
$2.95 · 1 In stock
Pro Tech Toolkit
$69.95 · 50+ In stock
