Installing Nexus S Motherboard
User-Contributed Guide
Replace the motherboard in your Samsung Nexus S.
  • Add Note x
  • x 3
Use this guide to replace the motherboard (includes rear camera and speaker).
Sections
Image #1
Add Note Edit Step 1 — Rear Panel  ¶
  • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
  • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
Image #1
Add Note Edit Step 2  ¶
  • Remove the rear panel from the Nexus S.
Image #1
Add Note Edit Step 3 — Battery  ¶
  • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
  • Remove the battery from the Nexus S.
Image #1 Image #2
Add Note Edit Step 4 — SIM Card  ¶
  • Use your thumb to slide the SIM card downwards from the SIM card slot.
  • Remove the SIM card.
Image #1
Add Note Edit Step 5 — Rear Inner Frame  ¶
  • Remove the six Phillips screws securing the rear inner frame to the inner case.
Image #1
Add Note Edit Step 6  ¶
  • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
  • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
Image #1 Image #2
Add Note Edit Step 7  ¶
  • Insert the plastic opening tool to the right of the power button.
  • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
Image #1 Image #2
Add Note Edit Step 8  ¶
  • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
Next » « Previous
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Plastic Opening Tools
$2.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 31 In stock
Inspection Scope
$39.95 · 40 In stock
Frictionless Ratchet
$24.95 · 49 In stock
Portable Anti-Static Mat
$24.95 · 19 In stock
Popular Products
Unibody Laptop Dual Drive
$39.95 · 50+ In stock
iPhone 4S Replacement Battery
T6 Torx Screwdriver
iPhone 5-Point Pentalobe Screwdriver
$12.95 · 50+ In stock
