Installing Nexus 7 Rear Panel
Replace the Rear Panel in your Nexus 7.
  • Add Note x
  • x 8
Use this guide to replace the Rear Panel.
Image #1
Add Note Edit Step 1 — Rear Panel  ¶
  • In the following steps you will release the clips (highlighted in red) along the perimeter of the Nexus 7's rear panel.
  • Do not use excessive force while prying the clips. They can be easily broken.
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Gently insert a plastic opening tool near the top of the Nexus 7 between the rear panel and the front panel assembly.
  • Carefully run the plastic opening tool along the top edge to pry the rear panel away from the front panel assembly of the Nexus 7.
Image #1 Image #2 Image #3
Add Note Edit Step 3  ¶
  • Insert the plastic opening tool between the rear panel and the front panel assembly near the power button and pry up at several points along the right edge of the Nexus 7.
Add Note Edit Step 4  ¶
  • Pry up the rear panel along the left edge using the method described in previous steps.
Image #1 Image #2
Add Note Edit Step 5  ¶
  • Gently lift and remove the rear panel up off the front panel assembly.
Required Tools
Plastic Opening Tools
$2.95 · 50+ In stock
Popular Products
iPad 2 Front Panel Assembly
$119.95 · 22 In stock
Heavy-duty Spudger
$4.95 · 48 In stock
Small Suction Cup
Illuminated Magnifier Table Lamp
$29.95 · 3 In stock
Precision Tweezers Set
$4.95 · 25 In stock
