Installing Nexus 7 Motherboard
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Replace the motherboard in your Nexus 7.
  • Add Note x
  • x 4
A faulty motherboard can lead to a myriad of performance issues. Use this guide to help you replace a damaged or malfunctioning motherboard.
Image #1
Add Note Edit Step 1 — Rear Panel  ¶
  • In the following steps you will release the clips (highlighted in red) along the perimeter of the Nexus 7's rear panel.
  • Do not use excessive force while prying the clips. They can be easily broken.
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Gently insert a plastic opening tool near the top of the Nexus 7 between the rear panel and the front panel assembly.
  • Carefully run the plastic opening tool along the top edge to pry the rear panel away from the front panel assembly of the Nexus 7.
Image #1 Image #2 Image #3
Add Note Edit Step 3  ¶
  • Insert the plastic opening tool between the rear panel and the front panel assembly near the power button and pry up at several points along the right edge of the Nexus 7.
Add Note Edit Step 4  ¶
  • Pry up the rear panel along the left edge using the method described in previous steps.
Image #1 Image #2
Add Note Edit Step 5  ¶
  • Gently lift and remove the rear panel up off the front panel assembly.
Image #1 Image #2
Add Note Edit Step 6 — Battery Cable  ¶
  • Using the tip of a spudger, push first on one side then the other to "walk" the battery cable straight out of its socket on the motherboard.
Image #1
Add Note Edit Step 7 — Speaker Cable  ¶
  • Peel back the copper ESD shielding covering the bottom of the motherboard.
  • Do not try to remove the copper shielding, as it is still attached underneath the battery.
Image #1
Add Note Edit Step 8  ¶
  • Using the tip of a spudger, push the speaker cable straight out of its socket on the motherboard.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Plastic Opening Tools
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 10 In stock
Popular Products
Unibody Laptop Dual Drive
$39.95 · 3 In stock
iPhone 4S Earpiece Speaker
$14.95 · 50+ In stock
Small Suction Cup
