Installing Motorola Droid 2 Front Panel
Replace a shattered front panel on your Droid 2.
  • Add Note x
  • x 11
This guide will take you through the process of installing a new front panel on your Motorola Droid 2.
Sections
first image
thumb image 1
thumb image 2
thumb image 3
  • Slide the battery cover toward the bottom edge of the phone.
  • Remove the battery cover from the rear of the phone.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Lift the battery out of the Droid 2 from the edge closest to the bottom of the phone.
  • Remove the battery from the Droid 2.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3 — Rear Case  ¶
  • Using the tip of a spudger, peel up one corner of the silver ribbon below the battery compartment.
  • Peel the ribbon off the phone.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ in stock
T5 Torx Screwdriver
$9.95 · 50+ in stock
T3 Torx Screwdriver
$9.95 · 38 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Anti-Static Wrist Strap
$7.95 · 46 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
Popular Products
iPhone 3G Front Panel Kit
$39.95 · 50+ in stock
iPhone 3G and 3GS Mute Button
$4.95 · 50+ in stock
26 Bit Driver Kit
$14.95 · 50+ in stock
Metal Grabber
$9.95 · 46 in stock
Probe Set
$6.95 · 16 in stock
