Installing Microsoft Zune HD Inner Chassis
  • Add Note x
Remove the inner chassis to access the OLED display panel.
Sections
first image
Add Note Edit Step 1 — Upper Rear Panel  ¶
  • Remove the four Tri-Wing screws securing the upper rear panel to the inner chassis.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Slightly rotate the top edge of the upper rear panel away from the Zune.
  • Lift the upper rear panel straight up off the black plastic lower rear panel.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3 — Lower Rear Panel  ¶
  • Insert a small Zune opening tool into the gap between the logic board and one side of the black plastic lower rear panel.
  • Carefully twist the Zune opening tool to pop the lower rear panel off the clips attaching it to the Zune.
  • Repeat this process for the other side of the lower rear panel.
Next » « Previous
