Installing Microsoft Zune HD Controls Sidebar
  • Add Note x
Unable to raise or lower the volume? Replace the controls sidebar and restore balance to the force.
first image
Add Note Edit Step 1 — Upper Rear Panel  ¶
  • Remove the four Tri-Wing screws securing the upper rear panel to the inner chassis.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Slightly rotate the top edge of the upper rear panel away from the Zune.
  • Lift the upper rear panel straight up off the black plastic lower rear panel.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3 — Controls Sidebar  ¶
  • Use a Zune opening tool to gently lift the media button lever off the post cast into the inner chassis.
  • Try not excessively rotate the media button lever about this post.
For more information, check out the Microsoft Zune HD device page.
Did you successfully follow this guide?
This guide has been completed 0 times.
