Installing Macintosh IIsi Ram
User-Contributed Guide
This guide is not managed by iFixit staff.
Incorrect Prerequisites
This guide has incorrect prerequisite guides.
  • Add Note x
The Macintosh IIsi uses 4 30-Pin RAM SIMMs, installed in pairs of two for a maximum capacity of 65MB (4X16MB + 1MB). It has 1MB of RAM soldered to the logic board.
Sections
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Top Case  ¶
  • Start by turning the computer around, and removing this screw:
  • There may or may not be a Phillips #0 screw here depending on whether or not the computer has ever been serviced.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2  ¶
  • Now lift these two clips, and slowly pivot the case up.
  • You can now seperate the top of the computer from the rest of the machine.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 3 — Ram  ¶
  • The IIsi uses 4 30-Pin SIMMs (Installed in pairs of 2) for a maximum ram capacity of 65MB. It has 1MB soldered to the logic board as well.
  • Start with this SIMM. Push these 2 metal tabs outward, then push the ram forward. It can then be lifted out. You have to remove the SIMMs in order, starting with the one you just removed. You can then work your way through all of them.
Next » « Previous
