Installing MacBook Unibody Model A1342 RAM
  • Add Note x
  • x 49
Accessing the RAM in this computer is straightforward and requires minimal disassembly.
Sections
Tools
first image
Add Note Edit Step 1 — Lower Case  ¶
  • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2  ¶
  • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
  • Slightly lift the lower case near the vent opening.
  • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
  • The location of these three clips is shown in the third picture.
first image
Add Note Edit Step 3 — Battery  ¶
  • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
  • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
  • It may be easier to use your fingernails to lift up on both sides of the connector.
Next » « Previous
