Installing MacBook Unibody Model A1278 Optical Drive
Prerequisite Only
This guide is only used as a prerequisite for other guides and is not a complete or useful guide when viewed independently.
Replacing the optical drive.
Embed this guide
With the HTML code below, you can embed this guide as a small widget on your website.
Edit Step 1
Access Door
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Edit Step 4
Lower Case
Edit Step 6
Optical Drive
The subwoofer is still connected to the right speaker, so don't completely remove it just yet.
Lift the subwoofer off the optical drive, and set it above the computer.
Lift the optical drive from its right edge and pull it out of the computer.
The hard drive cable may become disconnected from the logic board when removing the optical drive. Ensure it is connected during reassembly.
This guide has been completed 0 times.
