Installing MacBook Unibody Model A1278 Left Speaker
Restore balanced sound to your laptop by replacing the left speaker.
Embed this guide
With the HTML code below, you can embed this guide as a small widget on your website.
Edit
Step 1
Access Door
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Edit
Step 4
Lower Case
Edit
Step 8
Fan
Use a spudger to pry the fan connector straight up off the logic board.
It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
Edit
Step 11
Logic Board
In the next few steps, you will disconnect the highlighted cables which connect the logic board to the upper case.
Each connector is different, so the following steps will show you how disconnect each in detail.
Disconnect the battery cable connector by pulling it straight away from the logic board.
If you cannot grasp the cable with your fingers, a spudger and tweezers may be helpful for removal.
Using the tip of a spudger, flip up the keyboard ribbon cable retaining flap.
Pull the keyboard ribbon cable straight out of its socket.
Use the tip of a spudger to flip up the locking lever to release the IR sensor ribbon cable from its socket.
Use the tip of a spudger to pull the IR sensor ribbon cable straight away from the logic board.
Remove the following two screws securing the display data cable bracket to the upper case:
One 7mm Phillips screw.
One 5mm Phillips screw.
Remove the two 7 mm Phillips screws from the DC-in board.
Lift the display data cable bracket out of the upper case.
If present, remove the two 4mm Phillips screws securing the bottom case clip to the upper case.
Lift the bottom case clip out of the upper case.
Edit
Step 28
Microphone
Edit
Step 30
Left Speaker
For more information, check out the MacBook Unibody Model A1278
device page .
Fantastic! Great work!
Your profile has been updated to show that you completed Installing MacBook Unibody Model A1278 Left Speaker. Change your mind?
Oops, I actually didn't do it.
Did you successfully follow this guide?
I did it! Success!
This guide has been completed 0 times.
