Installing MacBook Unibody Model A1278 Display Assembly
Use this guide to replace a broken display on your MacBook Unibody.
Embed this guide With the HTML code below, you can embed this guide as a small widget on your website.
Tools (continued) Relevant parts
Edit Step 1
Access Door
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Edit Step 4
Lower Case
Edit Step 6
Display Assembly
Remove the following screws securing the camera data cable and right speaker to the upper case:
Slide the camera cable bracket out from under the subwoofer and remove it from the computer.
The iSight cable has an eyelet through which passes the left-most screw in these pictures.
Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-in side of the computer.
Pull the display data cable connector straight away from its socket.
Make sure to pull the connector straight away and not straight up from its socket.
Open your MacBook so the display is perpendicular to the upper case.
Place your opened MacBook on a table as pictured.
While holding the display and upper case together with your left hand, remove the 6 mm Torx screw from the lower display bracket.
Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
Remove the last remaining 6 mm Torx screw securing the display to the upper case.
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display away from the upper case, minding any brackets or cables that may get caught.
For more information, check out the MacBook Unibody Model A1278
device page .
Fantastic! Great work!
Your profile has been updated to show that you completed Installing MacBook Unibody Model A1278 Display Assembly. Change your mind? Oops, I actually didn't do it.
Did you successfully follow this guide? I did it! Success!
This guide has been completed 20 times.
