Page 1 of 1
Installing MacBook Unibody Model A1278 Display Assembly
- Author: Walter Galan
- Difficulty: Moderate
Use this guide to replace a broken display on your MacBook Unibody.
Tools (continued)
Relevant parts
- View:
- Paginated
- Full width
Edit Step 8 ¶
Remove the following screws securing the camera data cable and right speaker to the upper case:
One 9.9 mm partially threaded Phillips screw
One 9.6 mm threaded Phillips screw
One 4 mm Phillips screw
Slide the camera cable bracket out from under the subwoofer and remove it from the computer.
The iSight cable has an eyelet through which passes the left-most screw in these pictures.
Edit Step 14 ¶
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display away from the upper case, minding any brackets or cables that may get caught.
This guide has been completed 20 times.
Page 1 of 1
