Image #1
Add Note Edit Step 9  ¶
  • Remove the following three screws securing the fan to the upper case:
    • Two 5 mm Phillips screws.
    • One 7 mm Phillips screw.
Image #1
Add Note Edit Step 10  ¶
  • Lift the fan out of the upper case.
Image #1
Add Note Edit Step 11 — Logic Board  ¶
  • In the next few steps, you will disconnect the highlighted cables which connect the logic board to the upper case.
  • Each connector is different, so the following steps will show you how disconnect each in detail.
Image #1 Image #2
Add Note Edit Step 12  ¶
  • Remove the single Phillips screw securing the battery cable cover to the upper case.
  • Remove the battery cable cover from the upper case.
Image #1
Add Note Edit Step 13  ¶
  • Use a spudger to pry the battery level indicator cable connector straight up off the logic board.
Image #1
Add Note Edit Step 14  ¶
  • Disconnect the battery cable connector by pulling it straight away from the logic board.
  • If you cannot grasp the cable with your fingers, a spudger and tweezers may be helpful for removal.
Image #1 Image #2
Add Note Edit Step 15  ¶
  • Using the tip of a spudger, flip up the keyboard ribbon cable retaining flap.
  • Pull the keyboard ribbon cable straight out of its socket.
Image #1
Add Note Edit Step 16  ¶
  • Use the flat end of a spudger to pry the trackpad connector straight up off the logic board.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Related Products
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 16 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
