Installing MacBook Unibody Model A1278 Access Door
  • Add Note x
  • x 25
This guide will show you how to remove the Access Door from your laptop.
first image
Add Note Edit Step 1 — Access Door  ¶
  • With the case closed, place the Unibody top-side down on a flat surface.
  • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
first image
Add Note Edit Step 2  ¶
  • The access door should now be raised enough to lift it up and out of the Unibody.
For more information, check out the MacBook Unibody Model A1278 device page.
Did you successfully follow this guide?
This guide has been completed 25 times.
Related Products
