Installing MacBook Pro 17" Unibody Right Fan
Replace your MacBook Pro 17" Unibody's right fan.
  • Add Note x
Running hot? Use this guide to replace a worn-out right fan.
Sections
Tools
first image
Add Note Edit Step 1 — Lower Case  ¶
    • Seven 3 mm Phillips screws.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Wedge your fingers between the lower case and the vent, and lift upward to release the clips holding the lower case to the upper case.
  • Remove the lower case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3 — Battery  ¶
  • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
  • Grab the plastic tab attached to the battery connector and pull it toward the front edge of the device.
  • Pull the tab parallel to the face of the logic board.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4 — Right Fan  ¶
  • Use the flat end of a spudger to lift the right fan connector out of its socket on the logic board.
  • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
  • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
first image
Add Note Edit Step 5  ¶
  • Remove the three 3.1 mm Phillips screws securing the right fan to the logic board.
first image
Add Note Edit Step 6  ¶
  • Remove the right fan from the upper case, minding its cable that may get caught.
For more information, check out the MacBook Pro 17" Unibody device page.
Did you successfully follow this guide?
This guide has been completed 0 times.
