Installing MacBook Pro 17" Unibody RAM
Upgrade your MacBook Pro 17" Unibody's RAM for an instant increase in computer speed.
  • Add Note x
  • x 31
Use this guide to replace your MacBook Pro's RAM.
Sections
Tools
first image
Add Note Edit Step 1 — Lower Case  ¶
    • Seven 3 mm Phillips screws.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Wedge your fingers between the lower case and the vent, and lift upward to release the clips holding the lower case to the upper case.
  • Remove the lower case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3 — Battery  ¶
  • Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
  • Grab the plastic tab attached to the battery connector and pull it toward the front edge of the device.
  • Pull the tab parallel to the face of the logic board.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4 — RAM  ¶
  • Release the tabs on each side of the RAM chip by simultaneously pushing each tab away from the RAM.
  • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  • After the RAM chip has popped up, pull it straight out of its socket.
  • Repeat this process if a second RAM chip is installed.
For more information, check out the MacBook Pro 17" Unibody device page.
Did you successfully follow this guide?
This guide has been completed 31 times.
