Installing MacBook Pro 17" Unibody Optical Drive Cable
Replace a ripped optical drive cable on your MacBook Pro 17" Unibody.
Use this guide to replace your MacBook Pro's optical drive cable.
Embed this guide With the HTML code below, you can embed this guide as a small widget on your website.
Edit Step 1
Lower Case
Edit Step 3
Battery
Whenever working near the logic board, it is always wise to first disconnect the battery to avoid short circuits.
Grab the plastic tab attached to the battery connector and pull it toward the front edge of the device.
Pull the tab parallel to the face of the logic board.
Edit Step 4
Optical Drive
Before disconnecting the camera cable, a small plastic retainer stuck to the logic board must first be moved out of the way.
Use the tip of a spudger to push the small plastic cable retainer away from the camera cable socket for enough clearance to remove the camera cable.
Pull the camera cable toward the optical drive opening to disconnect it from the logic board.
The camera cable socket is very fragile. Do not apply any upward force to this socket, as it may break off the logic board. Pull the camera cable parallel to the face of the logic board.
If present, remove the small piece of EMI foam near the Bluetooth board.
De-route the camera cable from the slot molded into the Bluetooth board housing.
Remove the three 3.5 mm Phillips screws securing the optical drive to the upper case.
To remove the screw closest to the battery, it may be helpful to use a T6 Torx screwdriver to first remove the upper case bracket directly above it.
Edit Step 13
Optical Drive Cable
For more information, check out the MacBook Pro 17" Unibody
device page .
Fantastic! Great work!
Your profile has been updated to show that you completed Installing MacBook Pro 17" Unibody Optical Drive Cable. Change your mind? Oops, I actually didn't do it.
Did you successfully follow this guide? I did it! Success!
This guide has been completed 1 time.
