Page 1 of 1
Installing MacBook Pro 17" Unibody Heat Sink
Replace the heat sink on your MacBook Pro 17" Unibody.
- Author: Andrew Bookholt
- Difficulty: Difficult
Use this guide to replace your MacBook Pro's heat sink. Before reinstalling the heat sink, it is essential to apply a new layer of thermal paste.
Sections
- Lower Case 2 steps
- Battery 1 step
- Right Fan 3 steps
- Logic Board 17 steps
- Heat Sink 3 steps
Tools
Tools (continued)
Relevant parts
- View:
- Paginated
- Full width
Edit
Step 4
Right Fan
Use the flat end of a spudger to lift the right fan connector out of its socket on the logic board.
It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
Edit
Step 21
Lift the black plastic flap attached to the display data cable retainer and rotate it toward the DC-In side of the MacBook.
Pull the display data cable out of its socket.
The display data cable socket is very fragile. Do not lift the connector upward as you disconnect it, as the socket may break off the logic board. Pull the cable parallel to the face of the logic board.
Edit
Step 26
Remove the heat sink from the logic board.
If the heat sink appears to be stuck to the logic board after removing all eight screws, it may be helpful to use a spudger to separate the two components.
If you need to mount the heat sink back onto the logic board, we have a thermal paste guide that makes replacing the thermal compound easy.
This guide has been completed 0 times.
Page 1 of 1
