Page 1 of 1
Installing MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Lower Case
- Author: iRobot
- Difficulty: Difficult
Replacing the metal bottom case.
Sections
- Battery 1 step
- RAM Shield 2 steps
- Upper Case 7 steps
- Optical Drive 3 steps
- Logic Board 8 steps
- Heat Sink 11 steps
- Lower Case 9 steps
Tools
- View:
- Paginated
- Full width
Edit
Step 9
Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
Lift up the back of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
Edit
Step 13
Use one hand to pull back the speaker cable and use your other hand to lift the optical drive up and out of the computer.
If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
Edit
Step 22
Heat Sink
Disconnect the two antenna cables attached to the AirPort Extreme card.
The cable with the gray shielding attaches to the left side connector, while the cable with the white shielding attaches to the right side.
If you have a MacBook Pro 17" Model A1229, there are three antenna cables attached to the AirPort Extreme card instead of two.
Edit
Step 32
Lift the heat sink and attached fans out of the computer.
If you are replacing the heat sink, be sure to transfer the attached thermal sensor to your new heat sink.
If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
This guide has been completed 8 times.
Page 1 of 1
