Page 1 of 1
Installing MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board
- Author: iRobot
- Difficulty: Difficult
Provides power to the machine and includes all ports on the left side of the machine.
Sections
- Battery 1 step
- RAM Shield 2 steps
- Upper Case 7 steps
- Left Speaker 6 steps
- Left I/O Board 7 steps
Tools
- View:
- Paginated
- Full width
Edit
Step 9
Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
Lift up the back of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
Edit
Step 11
Left Speaker
Disconnect the two antenna cables attached to the AirPort Extreme card.
The cable with the gray shielding attaches to the left side connector, while the cable with the white shielding attaches to the right side.
For the A1261 model, The cable with the black shielding attaches to the left side connector, while the cable with the blue shielding attaches to the right side.
If you have a MacBook Pro 17" Model A1229 or A1212, there are three antenna cables attached to the AirPort Extreme card instead of two.
Edit
Step 23
Remove the following four screws:
One 3.2 mm black Phillips screw with a small head.
Three 1.3 mm silver Phillips screws with large heads.
If you have a MacBook Pro 17" Model A1229, remove the four 1.3 mm silver Phillips screws with large heads.
The I/O board is now free from the ExpressCard cage.
This guide has been completed 14 times.
Page 1 of 1
