Installing MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Left I/O Board Cable
  • Author: iRobot
  • Difficulty: Difficult
  • Add Note x
This connects the left I/O board to the logic board.
first image
  • Use your fingers to push both battery release tabs away from the battery and lift the battery out of the computer.
first image
Add Note Edit Step 2 — RAM Shield  ¶
  • Remove the four identical Phillips screws from the memory door.
first image
Add Note Edit Step 3  ¶
  • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
first image
Add Note Edit Step 4 — Upper Case  ¶
  • Remove the three Phillips screws in the battery compartment near the latch. Apple was nice enough to tilt these screws at a slight angle to make them easier to remove.
first image
Add Note Edit Step 5  ¶
  • Remove the following six screws:
    • Two T6 Torx screws on either side of the RAM slot.
    • Four Phillips screws along the hinge.
first image
Add Note Edit Step 6  ¶
  • Remove the four Phillips screws on the port side of the computer.
first image
Add Note Edit Step 7  ¶
  • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
first image
Add Note Edit Step 8  ¶
  • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
first image
Add Note Edit Step 9  ¶
  • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
  • Lift up the back of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
first image
Add Note Edit Step 10  ¶
  • Disconnect the trackpad and keyboard ribbon cable from the logic board.
  • Remove the upper case.
first image
Add Note Edit Step 11 — Left I/O Board Cable  ¶
  • Disconnect the hard drive ribbon cable and the left I/O board ribbon cable from the logic board.
  • Disconnect the right speaker connector from the left I/O board.
first image
Add Note Edit Step 12  ¶
  • Remove the two silver T6 Torx screws securing the gray metal retaining bracket to the right side of the hard drive.
  • Lift the gray metal retaining bracket out of the computer.
first image
Add Note Edit Step 13  ¶
  • Remove the five black T6 Torx screws securing the left I/O board to the lower case.
  • Disconnect the large power connector from the left I/O board.
first image
Add Note Edit Step 14  ¶
  • Move the orange hard drive ribbon out of the way with one hand. Use your other hand to lift up the right side of the left I/O board and slide it out of the computer.
first image
Add Note Edit Step 15  ¶
  • Turn the left I/O board over.
  • Use a spudger to disconnect the short orange cable from the left I/O board.
For more information, check out the MacBook Pro 17" Models A1151 A1212 A1229 and A1261 device page.
Did you successfully follow this guide?
This guide has been completed 1 time.
