Installing MacBook Pro 15" Unibody Mid 2010 Right Fan
Replace the right fan on your Mid 2010 MacBook Pro 15" Unibody.
  • Add Note x
Replacing a defective fan is pretty easy and will keep your laptop running cool.
first image
Add Note Edit Step 1 — Lower Case  ¶
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
first image
Add Note Edit Step 2  ¶
  • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
first image
Add Note Edit Step 3 — Right Fan  ¶
  • Remove three T6 Torx screws securing the right fan to the logic board and upper case.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4  ¶
  • Use a spudger to pry the fan connector straight up off the logic board.
  • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
  • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
first image
Add Note Edit Step 5  ¶
  • Lift the right fan out of the upper case.
For more information, check out the MacBook Pro 15" Unibody Mid 2010 device page.
Did you successfully follow this guide?
This guide has been completed 0 times.
