Page 1 of 1
Installing MacBook Pro 15" Unibody Mid 2010 Display
Replace a broken display assembly on your Mid 2010 MacBook Pro 15" Unibody.
- Author: Andrew Bookholt
- Difficulty: Moderate
Replacing a broken display assembly gives you a new LCD, front glass, display enclosure, iSight camera, and new AirPort antennas.
Tools (continued)
Relevant parts
- View:
- Paginated
- Full width
Edit Step 3
Battery
Remove the two 7.4 mm Y1 Tri-Wing screws securing the battery to the upper case.
Note: For certain repairs (e.g. hard drive), removing the battery is not necessary but it prevents any accidental shorting of electronics on the motherboard. If you do not remove the battery, please be careful as parts of the motherboard might be electrified.
You do not necessarily have to follow steps 3-6 to remove the battery in order to replace the hard drive. However it is recommended to remove all power sources from electronics before working on them.
Edit Step 15 ¶
Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
Pull the display data cable straight out of its socket on the logic board.
Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
Edit Step 20 ¶
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
This guide has been completed 5 times.
Page 1 of 1
