Installing MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Cable
Replace the AirPort/Bluetooth cable on your Mid 2010 MacBook Pro 15" Unibody.
  • Add Note x
Faulty Wi-Fi or Bluetooth connection? Replace the AirPort/Bluetooth cable.
first image
Add Note Edit Step 1 — Lower Case  ¶
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
first image
Add Note Edit Step 2  ¶
  • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3 — AirPort/Bluetooth Cable  ¶
  • Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
  • Carefully peel the AirPort/Bluetooth ribbon cable off the top of the black plastic AirPort/Bluetooth housing.
first image
Add Note Edit Step 4  ¶
  • Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off its socket on the AirPort/Bluetooth board.
For more information, check out the MacBook Pro 15" Unibody Mid 2010 device page.
Did you successfully follow this guide?
This guide has been completed 2 times.
