Installing MacBook Pro 15" Unibody Mid 2009 RAM
  • Add Note x
  • x 26
Upgrade your RAM for an instant increase in speed.
Sections
Tools
first image
Add Note Edit Step 1 — Lower Case  ¶
    • Seven 3 mm Phillips screws.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3 — RAM  ¶
  • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
  • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  • After the RAM chip has popped up, pull it straight out of its socket.
  • Repeat this process if a second RAM chip is installed.
For more information, check out the MacBook Pro 15" Unibody Mid 2009 device page.
Did you successfully follow this guide?
This guide has been completed 26 times.
