Installing MacBook Pro 15" Unibody Mid 2009 Optical Drive
Prerequisite Only
Prerequisite Only
This guide is only used as a prerequisite for other guides and is not a complete or useful guide when viewed independently.
  • Add Note x
This guide is an internal prerequisite and should remain unpublished.
first image
Add Note Edit Step 1 — Optical Drive  ¶
  • Apple sticks a small strip of clear plastic with adhesive applied to one side to the logic board behind the camera cable connector to keep it in its socket. When moving it out of the way, be sure not to break any surface-mount components off the logic board.
  • Hold the end of the cable retainer down with one finger while you use the tip of a spudger to slightly lift the other end and rotate it away from the camera cable connector.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Disconnect the camera cable by pulling the male end straight away from its socket.
  • Pull the connector parallel to the face of the logic board, not straight up.
first image
Add Note Edit Step 3  ¶
  • Peel the camera cable off the adhesive securing it to the optical drive.
first image
thumb image 1
thumb image 2
Add Note Edit Step 4  ¶
  • This step is only required if you have an anti-glare display. If you have a glossy display, skip this step.
  • Disconnect the Bluetooth cable by pulling the male end straight away from its socket.
  • Use the flat end of a spudger to pry the Bluetooth antenna cable from its socket on the board.
first image
thumb image 1
thumb image 2
Add Note Edit Step 5  ¶
  • Remove the two 8 mm Phillips screws securing the Bluetooth/camera cable retainer to the upper case.
  • One of the screws may remain captive in the Bluetooth/camera cable ground loop. If replacing the display, be sure to transfer this screw to the new unit.
  • Lift the Bluetooth board/cable retainer assembly out of the upper case.
first image
Add Note Edit Step 6  ¶
  • Use a spudger to pry the optical drive connector straight up off the logic board.
first image
Add Note Edit Step 7  ¶
  • Remove the single 3.5 mm Phillips screw securing the inner side of the optical drive to the upper case.
first image
Add Note Edit Step 8  ¶
  • Remove the two 3.5 mm Phillips screws securing the outer side of the optical drive to the upper case.
first image
Add Note Edit Step 9  ¶
  • Lift the optical drive from its left edge and pull it out of the upper case.
For more information, check out the MacBook Pro 15" Unibody Mid 2009 device page.
Did you successfully follow this guide?
This guide has been completed 0 times.
