Installing MacBook Pro 15" Unibody Late 2011 Optical Drive Replacement
Replace the optical drive on your Late 2011 MacBook Pro 15" Unibody.
  • Add Note x
MacBook Pro not reading CDs? Use this guide to replace a burned-out optical drive.
first image
Add Note Edit Step 1 — Lower Case  ¶
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
first image
Add Note Edit Step 2  ¶
  • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3 — Battery Connector  ¶
  • For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified.
  • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
  • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
Next » « Previous
