first image
thumb image 1
thumb image 2
Add Note Edit Step 34  ¶
  • Remove the following three Phillips screws securing the optical drive to the upper case:
    • One 3.5 mm Phillips screw.
    • Two 2.5 mm Phillips screws.
  • Lift the optical drive from its right edge and pull it out of the computer.
first image
thumb image 1
thumb image 2
Add Note Edit Step 35  ¶
  • Remove the following four screws securing the subwoofer and right speaker to the upper case:
    • Two 3.2 mm Phillips screws.
    • One 2.6 mm Phillips screw.
    • One 5 mm Phillips screw.
  • Lift the subwoofer and right speaker assembly out of the upper case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 36  ¶
  • Peel the hard drive cable from the adhesive securing it to the upper case, and maneuver the plastic retaining block out of the upper case.
Next » « Previous
