Page 1 of 1
Installing MacBook Pro 15" Unibody Late 2008 and Early 2009 Airport Card
User-Contributed Guide
This guide is not managed by iFixit staff.
How to replace the airport card in a MacBook Pro 15" Unibody late 2008/early 2009.
- Author: Will Budney
- Difficulty: Moderate
Sections
- Access Door 2 steps
- Battery 1 step
- Lower Case 2 steps
- Display Assembly 8 steps
- Airport Card 3 steps
- View:
- Paginated
- Full width
Edit Step 6
Display Assembly
If necessary, peel the EMI gasket off the camera cable connector.
Disconnect the camera cable by pulling the male end straight away from its socket toward the optical drive opening.
Do not try to lift this connector straight up off the board. Pull the connector parallel to the face of the logic board.
Deroute the camera data cable from the channel in the optical drive.
Edit Step 8 ¶
Grab the plastic pull tab secured to the LVDS cable lock and rotate it toward the DC-in side of the computer.
Pull the LVDS connector straight away from its socket.
When disconnecting the LVDS cable, do not pull on the black tab secured to the LVDS cable lock. We recommend wiggling the cable while applying tension to slowly "walk" the connector out of its socket.
Edit Step 13 ¶
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display away from the upper case, minding any brackets or cables that may get caught.
Edit Step 14
Airport Card
Slide the clutch cover toward the right edge of the display.
The clutch cover will move approximately .25" and stop. Do not force it too far to the right.
When reinstalling the clutch cover, be sure to slip it over the components protruding from the lower edge of the display about .25" to the right of its final installed position on the display.
Edit Step 15 ¶
Starting at its far left end, rock the clutch cover along its long axis while pulling it away from the clutch hinge.
Working from right to left, carefully continue to release and lift the clutch along the lower edge of the display assembly.
Lift the clutch cover up off the front bezel and set it aside.
When reinstalling the clutch cover, be sure to widen the opening when slipping it over the small black plastic cosmetic cover that fills the open end of the clutch cover when it is in place. The cosmetic cover has very thin and delicate plastic arms that hold it to the right clutch hinge.
This guide has been completed 7 times.
Page 1 of 1
