Image #1 Image #2
Add Note Edit Step 33  ¶
  • Use the tip of a spudger to push the AirPort cable retaining lock away from its socket on the AirPort board.
  • Pull the AirPort cable straight out of its socket on the AirPort board.
  • Do not lift up on the AirPort cable, as its socket is very fragile. Pull the cable parallel to the face of the AirPort board.
Image #1 Image #2
Add Note Edit Step 34  ¶
  • De-route the iSight ribbon cable from its channel near the top right corner of the display assembly.
  • Continue de-routing the AirPort/iSight cable from the right side of the display assembly.
Image #1
Add Note Edit Step 35  ¶
  • Carefully pull half of the AirPort/iSight cable through the opening located underneath the right hinge.
  • Do not pull the AirPort/iSight cable completely through the opening. The right hinge prevents the cable from complete removal. Forcing the cable through the opening may cause severe damage to your AirPort/iSight cable.
Image #1 Image #2 Image #3
Add Note Edit Step 36  ¶
  • Remove three 2.5 mm T6 Torx screws securing the right hinge to the display assembly.
  • Remove the right hinge up off the display assembly.
Image #1
Add Note Edit Step 37  ¶
  • Pull the AirPort/iSight cable through the opening located near the bottom right corner of the display assembly.
  • Remove the AirPort/iSight cable from the display assembly.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
T6 Torx Screwdriver
$4.95 · 50+ In stock
Phillips #00 Screwdriver
Heat Gun
$24.95 · 20 In stock
Heavy-duty Suction Cups (Pair)
$14.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 7 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
Popular Device Products
Unibody Laptop Dual Drive
$39.95 · 50+ In stock
Arctic Silver Thermal Paste
$8.95 · 50+ In stock
Arctic Silver ArctiClean
$7.95 · 11 In stock
