Installing MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Logic Board
Prerequisite Only
Prerequisite Only
This guide is only used as a prerequisite for other guides and is not a complete or useful guide when viewed independently.
  • Add Note x
This guide is an internal private guide used as a prereq.
first image
Add Note Edit Step 1 — Logic Board  ¶
  • Apple sticks a small strip of clear plastic with adhesive applied to one side to the logic board behind the camera cable connector to keep it in its socket. When moving it out of the way, be sure not to break any surface-mount components off the logic board.
  • Hold the end of the cable retainer down with one finger while you use the tip of a spudger to slightly lift the other end and rotate it away from the camera cable connector.
first image
Add Note Edit Step 2  ¶
  • Disconnect the camera cable by pulling the male end straight away from its socket.
  • Pull the connector parallel to the face of the logic board, not straight up.
first image
Add Note Edit Step 3  ¶
  • Use the flat end of a spudger to pry the optical drive cable connector up off the logic board.
Next » « Previous
