Installing MacBook Pro 15" Retina Display Mid 2012 Battery
Private
Private
This guide will not appear in search results and can only be viewed by team members!
Replace the battery in your MacBook Pro 15" Retina Display Mid 2012.
Low batteries in your MacBook Pro with Retina display got you down? Use this guide to replace the battery.
WARNING: Removing the battery is very difficult. There is always a chance of inhaling noxious fumes and lighting the battery on fire. Work in a well ventilated area.
Image #1
Add Note Step 1 — Lower Case  ¶
  • Remove the following pentalobe screws securing the lower case to the MacBook Pro with Retina display.
    • Eight 3.0 mm
    • Two 2.3 mm
Image #1
Add Note Step 2  ¶
  • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
  • Set the lower case aside.
Image #1
Add Note Step 3 — Battery Connector  ¶
  • Peel back the warning label covering the battery connector.
Image #1 Image #2
Add Note Step 4  ¶
  • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
  • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
Image #1
Add Note Step 5 — AirPort/Camera Cable  ¶
  • Use the tip of a spudger to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
Image #1
Add Note Step 6  ¶
  • Use the tip of a spudger to push the camera cable connector out of its socket on the logic board.
    • Be sure to push parallel to the board, pushing first on one side, then the other to "walk" the connector out of its socket.
Image #1 Image #2 Image #3
Add Note Step 7  ¶
  • Insert the flat end of a spudger underneath the rubber heat sink cover on the right fan.
  • Slide the spudger underneath the length of the cover, releasing the adhesive.
  • Lift the cover and flip it back so that you can access the cables underneath.
Add Note Step 8  ¶
  • Use your fingers to pull the AirPort/Camera cables up off the fan.
    • The cables are adhered to the fan, so peel them up carefully to prevent ripping any.
  • Carefully de-route the cables from the plastic cable guide.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
T5 Torx Screwdriver
$6.95 · 50+ In stock
Plastic Opening Tools
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 24 In stock
Inspection Scope
$39.95 · 39 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 18 In stock
Popular Products
iPhone 4S Display Assembly
$94.95 · 50+ In stock
Spudger
T8 Torx Security Bit Screwdriver
iPhone 5-Point Pentalobe Screwdriver
$12.95 · 50+ In stock
