Installing MacBook Pro 15" Retina Display Mid 2012 Battery
Private
This guide will not appear in search results and can only be viewed by team members!
Replace the battery in your MacBook Pro 15" Retina Display Mid 2012.
- Author: Brett Hartt
- Difficulty: Very difficult
Low batteries in your MacBook Pro with Retina display got you down? Use this guide to replace the battery.
WARNING: Removing the battery is very difficult. There is always a chance of inhaling noxious fumes and lighting the battery on fire. Work in a well ventilated area.
Sections
- Lower Case 2 steps
- Battery Connector 2 steps
- AirPort/Camera Cable 4 steps
- I/O Board Cable 1 step
- Right Fan 5 steps
- Left Fan 3 steps
- Rubber Hinge Covers 1 step
- SSD 2 steps
- I/O Board 2 steps
- Logic Board Assembly 11 steps
Sections (continued)
Tools
- View:
- Single page
Step 1
Lower Case
Remove the following pentalobe screws securing the lower case to the MacBook Pro with Retina display.
Eight 3.0 mm
Two 2.3 mm
Step 2 ¶
Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
Set the lower case aside.
Step 3
Battery Connector
Peel back the warning label covering the battery connector.
Step 4 ¶
Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
Step 5
Use the tip of a spudger to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
Step 6 ¶
Use the tip of a spudger to push the camera cable connector out of its socket on the logic board.
Be sure to push parallel to the board, pushing first on one side, then the other to "walk" the connector out of its socket.
Step 7 ¶
Insert the flat end of a spudger underneath the rubber heat sink cover on the right fan.
Slide the spudger underneath the length of the cover, releasing the adhesive.
Lift the cover and flip it back so that you can access the cables underneath.
Step 8 ¶
Use your fingers to pull the AirPort/Camera cables up off the fan.
The cables are adhered to the fan, so peel them up carefully to prevent ripping any.
Carefully de-route the cables from the plastic cable guide.
Page 1 of 6
