first image
Add Note Edit Step 25  ¶
  • Be cautious to not put any strain on the inverter cable ground loop, as it is a very thin and delicate wire.
  • Disconnect the inverter cable by pulling its connector away from the socket on the inverter.
first image
thumb image 1
thumb image 2
Add Note Edit Step 26 — Clutch Assembly  ¶
  • Remove the pieces of yellow kapton tape from the bottom left corner of the display.
  • Peel the three green antenna ground straps off the copper tape along the bottom edge of the LCD.
    • The adhesive connecting these straps to the display is very strong. An edged tool is helpful to separate the adhesive while you peel the straps off.
  • Remove the piece of tape securing the camera cable to the LCD.
first image
thumb image 1
thumb image 2
Add Note Edit Step 27  ¶
  • Remove the pieces of tape covering the display data cable and camera cable connectors.
  • Carefully peel the camera cable off the foam tape along the top edge of the LCD.
Next » « Previous
