Page 1 of 1
Installing MacBook Pro 15" Core Duo Model A1150 LCD Panel High Definition (1920x1200)
- Author: Ben Eisenman
- Difficulty: Very difficult
By following this guide, you can install a high-definition LCD panel on your MacBook Pro!
Sections
- Battery 1 step
- Memory Door 2 steps
- Upper Case 7 steps
- Display Assembly 7 steps
- Rear Display Bezel 5 steps
- LCD Panel 10 steps
- LCD Panel High Definition (1920x1200) 6 steps
- View:
- Paginated
- Full width
Edit
Step 9
Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case. This stage can be quite tricky. Over the DVD reader are 4 tabs set back which pull out vertically.
Note that the two small tongues on the left hand front of the upper case may bend while you remove the upper case. When re-installing, you may need to bend them back to fit in the grooves in the lower case.
Edit
Step 19
Insert the flat end of a spudger perpendicular to the face of the display between the plastic strip attached to the rear bezel and the front bezel.
Do not insert your spudger between the plastic strip and the rear bezel.
With the spudger still inserted, rotate it away from the display to separate the front and rear bezels.
Work along the left edge of the display until the rear bezel is evenly separated from the front bezel.
Edit
Step 20
Work along the right edge of the display until the rear bezel is evenly separated from the front bezel.
Edit
Step 21
Insert the flat end of a spudger between the front bezel and the plastic strip attached to the rear bezel near the screw holes at the bottom corners of the display.
Rotate your spudger toward the rear bezel to separate it from the front bezel.
If necessary, enlarge the gap between the lower edge of the rear bezel and the clutch cover until the two components are completely separated.
Edit
Step 23
LCD Panel
Remove the pieces of yellow kapton tape from the bottom left corner of the display.
Remove the pieces of tape securing the display data cable and camera cable to the display.
Peel the three green antenna ground straps off the copper tape along the bottom edge of the LCD.
The adhesive connecting these straps to the display is very strong. An edged tool is helpful to separate the adhesive while you peel the straps off.
Remove the piece of tape securing the camera cable to the LCD.
Edit
Step 28
The next few steps will require you to separate the LCD from the adhesive applied to the upper and lower edges of the front bezel. A heat gun may be helpful to soften the adhesive to prevent damaging the LCD panel during removal.
The adhesive is applied such that it sticks to a thin steel strip around the perimeter of the LCD. When prying your LCD away from the front panel, be sure you are separating the front panel from the steel strip on the LCD.
Use the flat end of a spudger to gently lift one of the top corners of the LCD out of the front bezel.
Edit
Step 33
Reconnect the following connectors back in their respective sockets on the logic board:
Camera connector cable
Inverter cable
Left fan
Display data cable
Do not reassemble the display to the lower case assembly just yet. The display can lay next to the laptop.
Edit
Step 36
Connect an external USB mouse to your MacBook Pro.
Power up the MacBook Pro and boot into the OS.
Carefully lift the upper case and use a spudger to pry the trackpad/keyboard ribbon cable up off the logic board. Remove the upper case from the computer.
Use your external mouse to select the "Sleep" option from the Apple menu.
Make sure that the sleep light is pulsing before continuing.
Edit
Step 38
Use a spudger to re-seat the trackpad/keyboard ribbon cable connector to its socket on the logic board.
This will wake the machine from sleep mode.
The MacBook Pro will now readjust itself to a resolution of 1920 x 1200!
The high definition resolution will be retained upon rebooting your MacBook Pro. However, if you reset your machine's PRAM/NVRAM, it will revert to standard definition, and you will need to redo the entire process!
This guide has been completed 3 times.
Page 1 of 1
