Page 1 of 1
Installing MacBook Pro 15" Core Duo Model A1150 Clutch Cover
- Author: Andrew Bookholt
- Difficulty: Very difficult
Use this guide to replace a damaged aluminum clutch cover.
Sections
- Battery 1 step
- Memory Door 2 steps
- Upper Case 7 steps
- Display Assembly 7 steps
- Rear Display Bezel 5 steps
- Display Inverter 3 steps
- Clutch Assembly 7 steps
- Antenna Cover 2 steps
- Antenna Cables 1 step
- Clutch Cover 1 step
Tools
Relevant parts
- View:
- Paginated
- Full width
Edit
Step 9
Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case. This stage can be quite tricky. Over the DVD reader are 4 tabs set back which pull out vertically.
Note that the two small tongues on the left hand front of the upper case may bend while you remove the upper case. When re-installing, you may need to bend them back to fit in the grooves in the lower case.
Edit
Step 19
Insert the flat end of a spudger perpendicular to the face of the display between the plastic strip attached to the rear bezel and the front bezel.
Do not insert your spudger between the plastic strip and the rear bezel.
With the spudger still inserted, rotate it away from the display to separate the front and rear bezels.
Work along the left edge of the display until the rear bezel is evenly separated from the front bezel.
Edit
Step 20
Work along the right edge of the display until the rear bezel is evenly separated from the front bezel.
Edit
Step 21
Insert the flat end of a spudger between the front bezel and the plastic strip attached to the rear bezel near the screw holes at the bottom corners of the display.
Rotate your spudger toward the rear bezel to separate it from the front bezel.
If necessary, enlarge the gap between the lower edge of the rear bezel and the clutch cover until the two components are completely separated.
Edit
Step 26
Clutch Assembly
Remove the pieces of yellow kapton tape from the bottom left corner of the display.
Peel the three green antenna ground straps off the copper tape along the bottom edge of the LCD.
The adhesive connecting these straps to the display is very strong. An edged tool is helpful to separate the adhesive while you peel the straps off.
Remove the piece of tape securing the camera cable to the LCD.
Edit
Step 29
If you have a Core Duo machine, refer to picture 1 and remove three Phillips screws connecting the clutch assembly to the lower edge of the front display bezel near the display data cable.
If you have a Core 2 Duo Model A1211 machine, refer to picture 2 and remove two Phillips screws connecting the clutch assembly to the lower edge of the front display bezel near the display data cable.
This guide has been completed 0 times.
Page 1 of 1
