Page 1 of 1
Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Left Thermal Sensor
- Author: Walter Galan
- Difficulty: Difficult
This detects the internal temperature of your machine for heat management.
Sections
- Battery 1 step
- RAM Shield 1 step
- Upper Case 7 steps
- Optical Drive 2 steps
- Logic Board 10 steps
- Heat Sink 1 step
- Left Thermal Sensor 2 steps
Tools
Tools (continued)
Relevant parts
- View:
- Paginated
- Full width
Edit
Step 8
Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
There are four plastic clips above the DVD slot, and another above and to the left of the IR sensor. These clips can be very difficult to disengage without prying. They can also be difficult to re-engage during reassembly.
Edit
Step 9
Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
Note: It is possible to replace the hard drive without disconnecting the keyboard from the chassis, but it will need to be held upright to keep it out of the way, while still allowing you both hands to work on the drive removal. Be careful when removing the keyboard-trackpad ribbon cable to ensure that the rear of the upper case is disengaged from the area near the hinge. It is easy to accidentally bend the screw receivers on either side of the keyboard.
Remove the upper case.
Edit
Step 11
Remove the following 4 screws:
Two 3.3 mm silver Phillips screws on either side of the SuperDrive.
One 4.7 mm silver T6 Torx screw from the top left corner of the drive.
One 6.2 mm black Phillips screw at the top right corner of the drive.
Lift the optical drive up and out of the computer.
Edit
Step 19
Remove the following 15 screws:
One 4.4 mm black Phillips screw to the right of the ram slot.
Eight 4.7 mm silver T6 Torx screws securing the logic board to the lower case.
One 6.2 mm black T6 Torx screw on the right side of the left fan.
Five 9.4 mm silver T6 Torx screws securing the left and right fans.
Edit
Step 20
Hold the logic board down with one hand and use your other hand to lift the left fan up from its housing. There is a piece of black tape securing the left fan to the heat sink. Carefully peel this tape up from the heat sink as you lift the left fan up.
Place the left fan above the Airport card. It is not necessary to remove the fan from the computer entirely.
Lift the right fan up and carefully peel up the tape securing the fan to the heat sink as you go.
Remove the right fan from the computer.
If you leave the upper orange screws on, the heatsink/pipes come out effortlessly, still mounted onto the main board. That way the thermal connections are retained.
Edit
Step 21
Lift up the left side of the logic board and disconnect the gray and black power cable from the bottom of the board.
Pull the power cable connector parallel to the face of the logic board.
Grasp the logic board at the left side and at the thin section, and rotate the logic board out of the lower case.
Edit
Step 22
Heat Sink
Gently lift the heat sink out of the computer.
Peel back the orange Kapton tape covering the middle thermal sensor.
Use a spudger to pry the middle thermal sensor off the heat sink.
Heat sink remains.
If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
This guide has been completed 0 times.
Page 1 of 1
