first image
Add Note Edit Step 10 — Left Fan  ¶
  • Use a spudger to disconnect the iSight cable from the logic board by sliding the cable to the left and out of its connector.
first image
thumb image 1
thumb image 2
Add Note Edit Step 11  ¶
  • Disconnect the left fan and left ambient light sensor cables by placing a spudger beneath each cable and lifting up.
    • Pry up from beneath the wires.
  • Peel up the left ambient light sensor cable from above the left fan, removing tape as necessary.
first image
thumb image 1
thumb image 2
Add Note Edit Step 12  ¶
  • Remove the following 3 screws:
    • One 6.2 mm black T6 Torx screw from the right side of the fan.
    • Two 9.4 mm silver T6 Torx screws from the left side of the fan.
  • Lift the fan up; carefully peel up the tape that secures the fan to the heat sink as you go.
Next » « Previous
For more information, check out the MacBook Pro 15" Core 2 Duo Models A1226 and A1260 device page.
Did you successfully follow this guide?
This guide has been completed 84 times.
