Installing MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board
  • Author: iRobot
  • Difficulty: Difficult
  • Add Note x
  • x 17
Provides power to the machine and includes all ports on the left side of the machine.
Sections
Tools
first image
  • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
first image
Add Note Edit Step 2 — RAM Shield  ¶
  • Remove the three identical Phillips screws from the memory door.
first image
Add Note Edit Step 3  ¶
  • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
first image
Add Note Edit Step 4 — Upper Case  ¶
  • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
first image
Add Note Edit Step 5  ¶
  • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
first image
Add Note Edit Step 6  ¶
  • Remove the four 3.2 mm Phillips screws on the port side of the computer.
first image
Add Note Edit Step 7  ¶
  • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
first image
Add Note Edit Step 8  ¶
  • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
first image
Add Note Edit Step 9  ¶
  • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
  • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
first image
Add Note Edit Step 10  ¶
  • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
  • Remove the upper case.
first image
Add Note Edit Step 11 — Left Fan  ¶
  • Disconnect the iSight cable from the logic board by sliding the cable to the left and out of its connector.
first image
Add Note Edit Step 12  ¶
  • Disconnect the inverter, left fan, and left ambient light sensor cables by placing a spudger beneath each cable and lifting up.
first image
Add Note Edit Step 13  ¶
  • Peel up the left ambient light sensor cable from above the left fan, removing tape as necessary.
first image
Add Note Edit Step 14  ¶
  • Remove the following 3 screws:
    • One 6.2 mm black T6 Torx screw from the right side of the fan.
    • Two 9.4 mm silver T6 Torx screws from the left side of the fan.
first image
Add Note Edit Step 15  ¶
  • Lift the lift fan up and carefully peel up the tape securing the fan to the heat sink as you go.
first image
Add Note Edit Step 16 — Left I/O Board  ¶
  • Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
first image
Add Note Edit Step 17  ¶
  • Disconnect the three antenna cables attached to the Airport Extreme card.
  • Apple was kind enough to include a label showing where each color antenna cable plugs in - just make sure to look at this when reconnecting the antenna cables.
first image
Add Note Edit Step 18  ¶
  • Remove the single black T6 Torx screw located just above the Airport Extreme card.
first image
Add Note Edit Step 19  ¶
  • Lift the Airport Extreme card up and slide it out of its connector.
first image
Add Note Edit Step 20  ¶
  • Deroute the Airport antenna cables from their channel in the left speaker.
first image
Add Note Edit Step 21  ¶
  • Peel up the orange hard drive cable from above the ExpressCard cage.
first image
Add Note Edit Step 22  ¶
  • Disconnect the speaker cable from the corner of the left I/O board.
first image
Add Note Edit Step 23  ¶
  • Lift the left speaker assembly out of its housing and place it in the area previously occupied by the left fan.
first image
Add Note Edit Step 24  ¶
  • Disconnect the large gray and black power cable from the left I/O board.
first image
Add Note Edit Step 25  ¶
  • Remove the following 5 screws/standoffs:
    • Four black T6 Torx screws securing the left I/O board to the lower case.
    • One 4 mm standoff located between the audio jacks.
first image
Add Note Edit Step 26  ¶
  • Lift up the right side of the left I/O board and slide it out of the computer.
first image
Add Note Edit Step 27  ¶
  • Remove the four Phillips screws securing the ExpressCard cage to the left I/O board.
first image
Add Note Edit Step 28  ¶
  • Lift the left I/O board off the ExpressCard cage.
first image
Add Note Edit Step 29  ¶
  • Disconnect the short left I/O board cable.
  • Left I/O board remains.
For more information, check out the MacBook Pro 15" Core 2 Duo Model A1211 device page.
Did you successfully follow this guide?
This guide has been completed 17 times.
Required Tools
Spudger
$2.95 · 50+ in stock
T6 Torx Screwdriver
$4.95 · 50+ in stock
Phillips #00 Screwdriver
4mm Nut Driver
$9.95 · 15 in stock
Related Products
Recommended Tools
Home Tech Toolkit
$24.95 · 22 in stock
Sorting Tray
$7.95 · 16 in stock
Anti-Static Wrist Strap
$7.95 · 50+ in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$9.95 · 50+ in stock
