Installing MacBook Pro 15" Core 2 Duo Model A1211 Keyboard
  • Author: iRobot
  • Difficulty: Moderate
  • Add Note x
  • x 47
This guide shows the hidden screws you must remove when replacing the keyboard.
Sections
Tools
first image
  • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
first image
Add Note Edit Step 2 — RAM Shield  ¶
  • Remove the three identical Phillips screws from the memory door.
first image
Add Note Edit Step 3  ¶
  • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
first image
Add Note Edit Step 4 — Upper Case  ¶
  • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
first image
Add Note Edit Step 5  ¶
  • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
first image
Add Note Edit Step 6  ¶
  • Remove the four 3.2 mm Phillips screws on the port side of the computer.
first image
Add Note Edit Step 7  ¶
  • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
first image
Add Note Edit Step 8  ¶
  • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
first image
Add Note Edit Step 9  ¶
  • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
  • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
first image
Add Note Edit Step 10  ¶
  • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
  • Remove the upper case.
first image
Add Note Edit Step 11 — Keyboard  ¶
  • Use a spudger to pry up the translucent plastic sheath covering the keyboard connector.
first image
Add Note Edit Step 12  ¶
  • Use the tip of a spudger to flip up the black plastic flaps locking down the keyboard and keyboard backlight ribbon cables.
first image
Add Note Edit Step 13  ¶
  • Slide the orange keyboard backlight ribbon out of its connector.
first image
Add Note Edit Step 14  ¶
  • Peel up the orange tape covering the keyboard backlight connector.
first image
Add Note Edit Step 15  ¶
  • Use the tip of a spudger to flip up the brown plastic flap locking down the keyboard backlight ribbon cable.
first image
Add Note Edit Step 16  ¶
  • Use a spudger or your finger to slide the keyboard backlight ribbon out of its connector.
first image
Add Note Edit Step 17  ¶
  • Carefully peel up the orange ribbon cable which carries the power and sleep signals, removing tape as necessary.
first image
Add Note Edit Step 18  ¶
  • Peel back the black protective sheath on the right side of the upper case. It is not necessary to fully remove this shield. Simply peel it back enough to access the screws beneath.
first image
Add Note Edit Step 19  ¶
  • Peel back the black protective sheath on the left side of the upper case. It is not necessary to fully remove this shield. Simply peel it back enough to access the screws beneath.
first image
Add Note Edit Step 20  ¶
  • Remove the ten identical Phillips screws attaching the keyboard to the casing.
first image
Add Note Edit Step 21  ¶
  • There are four locking tabs along the back edge of the keyboard holding it in place. These tabs must be straightened before you can remove the keyboard.
first image
Add Note Edit Step 22  ¶
  • The first frame shows a tab in the "locked" position and the second frame shows the same tab in the "unlocked" position.
  • Use needlenose pliers or a spudger to bend each of the four tabs so that they are all in the "unlocked" position.
first image
Add Note Edit Step 23  ¶
  • Slide the keyboard ribbon out of its connector.
  • If the keyboard ribbon won't slide out, make sure that the black plastic flap holding the ribbon in place is vertical.
first image
Add Note Edit Step 24  ¶
  • Place the upper casing on its edge and use a spudger to push the keyboard away from the casing, poking the spudger through the central keyboard screw hole. Grasp the keyboard as it separates from the casing.
first image
Add Note Edit Step 25  ¶
  • Maintaining your hold on the keyboard, lay the casing flat and gently bow the keyboard until the two tabs on either side of the keyboard come free.
  • Slide the keyboard away from the trackpad and out of the upper case.
  • When reversing the steps and installing the new keyboard, be sure to carefully insert the keyboard ribbon and the keyboard backlight ribbon into their respective slots in the upper case before reinserting the tabs on either side of the keyboard.
For more information, check out the MacBook Pro 15" Core 2 Duo Model A1211 device page.
Did you successfully follow this guide?
This guide has been completed 47 times.
