Installing MacBook Pro 15" Core 2 Duo Model A1211 Display Data Cable
  • Add Note x
Display connection issues? Use this guide to replace a faulty display data cable rather than replacing the entire display.
Sections
first image
  • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
first image
Add Note Edit Step 2 — RAM Shield  ¶
  • Remove the three identical Phillips screws from the memory door.
first image
Add Note Edit Step 3  ¶
  • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
Next » « Previous
