Installing MacBook Pro 15" Core 2 Duo Model A1211 Display Assembly
  • Author: iRobot
  • Difficulty: Moderate
  • Add Note x
  • x 6
Change out the entire display assembly, including the inverter, Airport antennas, hinges and casing.
Sections
Tools
first image
  • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
first image
Add Note Edit Step 2 — RAM Shield  ¶
  • Remove the three identical Phillips screws from the memory door.
first image
Add Note Edit Step 3  ¶
  • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ in stock
T6 Torx Screwdriver
$4.95 · 50+ in stock
Phillips #00 Screwdriver
Related Products
Recommended Tools
Home Tech Toolkit
$24.95 · 22 in stock
Sorting Tray
$7.95 · 16 in stock
Anti-Static Wrist Strap
$7.95 · 50+ in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$9.95 · 50+ in stock
