Installing MacBook Pro 15" Core 2 Duo Model A1211 Airport Extreme
  • Author: iRobot
  • Difficulty: Moderate
  • Add Note x
  • x 4
Install an Airport Extreme 802.11g card internally.
Sections
Tools
first image
  • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
first image
Add Note Edit Step 2 — RAM Shield  ¶
  • Remove the three identical Phillips screws from the memory door.
first image
Add Note Edit Step 3  ¶
  • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
first image
Add Note Edit Step 4 — Upper Case  ¶
  • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
first image
Add Note Edit Step 5  ¶
  • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
first image
Add Note Edit Step 6  ¶
  • Remove the four 3.2 mm Phillips screws on the port side of the computer.
first image
Add Note Edit Step 7  ¶
  • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
first image
Add Note Edit Step 8  ¶
  • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
first image
Add Note Edit Step 9  ¶
  • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
  • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
first image
Add Note Edit Step 10  ¶
  • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
  • Remove the upper case.
first image
Add Note Edit Step 11 — Airport Extreme  ¶
  • Disconnect the three antenna cables attached to the Airport Extreme card.
  • Apple was kind enough to include a label showing where each color antenna cable plugs in - just make sure to look at this when reconnecting the antenna cables.
first image
Add Note Edit Step 12  ¶
  • Remove the single black T6 Torx screw located just above the Airport Extreme card.
first image
Add Note Edit Step 13  ¶
  • Lift the small silver metal retaining bracket up and out of the computer.
first image
Add Note Edit Step 14  ¶
  • Lift the Airport Extreme card up and slide it out of its connector.
For more information, check out the MacBook Pro 15" Core 2 Duo Model A1211 device page.
Did you successfully follow this guide?
This guide has been completed 4 times.
Required Tools
Spudger
$2.95 · 50+ in stock
T6 Torx Screwdriver
$4.95 · 50+ in stock
Phillips #00 Screwdriver
Related Products
Recommended Tools
Home Tech Toolkit
$24.95 · 22 in stock
Sorting Tray
$7.95 · 16 in stock
Anti-Static Wrist Strap
$7.95 · 50+ in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$9.95 · 50+ in stock
