Installing MacBook Pro 13" Unibody Mid 2009 Logic Board
Prerequisite Only
Prerequisite Only
This guide is only used as a prerequisite for other guides and is not a complete or useful guide when viewed independently.
  • Add Note x
This guide is an internal private guide used as a prereq.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 1 — Logic Board  ¶
  • Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-in side of the computer.
  • Pull the display data cable connector straight away from its socket.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Remove the following two screws securing the display data cable bracket to the upper case:
    • One 7 mm Phillips.
    • One 5 mm Phillips.
  • Lift the display data cable bracket out of the upper case.
first image
Add Note Edit Step 3  ¶
  • Use the flat end of a spudger to pry the subwoofer and right speaker connector up off the logic board.
Next » « Previous
