Installing MacBook Pro 13" Unibody Mid 2009 Hard Drive Cable
  • Add Note x
  • x 52
This guide will show you how to replace your hard drive cable or tighten it if it is loose
Sections
Tools
Relevant parts
first image
Add Note Edit Step 1 — Lower Case  ¶
  • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Seven 3 mm Phillips screws.
first image
Add Note Edit Step 2  ¶
  • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
first image
Add Note Edit Step 3 — Battery  ¶
  • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
  • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Next » « Previous
